Power Steering issues
MandJ_01
ok guys heres what I have, replaced master cylinder but did not bench bled,I did bled the brakes also filled power steering turned wheels and added more to level. Now when I turn the wheels in park everything ok but when I put it into drive the wheel stop halfway and than there smoke and the smell of burning rubber from the dog house also the fan slows down and stops as I turn the wheel, It all goes away when I let the wheel go. Does this have anything to with the Hydro boost system?
89 Southwind Ford 460 F53
17 REPLIES 17
MandJ_01
rgatijnet1 wrote:
Could you have put in too much power steering fluid which is overflowing and spraying on hot engine parts and the belts when you turn the wheel?
The level looks good but I will check again.
rgatijnet1
enblethen
Sounds like a belt issue. Verify belt alignment and tensioning.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
