I'm troubleshooting an issue with one of my slideout's.
When starting to retract the slideout it throws a fault and stops. Putting it into manual override works every time *but* the buttons appear to be wired backwards.
When pressing the "in" button that is on the left side of the panel, it moves the forward motor or what I would call the right motor.
When pressing the "out" button that is on the right side of the panel, it moves the rear motor or what I would call the left motor.
On page four of this .pdf:
https://lci-support-doc.s3.amazonaws.com/manuals/pg_3010002129.pdf
the sidebar indicates that the "in" button should be moving the rear motor and the "out" button the front motor.
My question is, is it normal for Winnebago to cross wire it up this way or could I be dealing with someone prior to myself goofing it up?
Thanks!
2011 Sightseer 35J
1995 Vectra 34RA
