Powergear touch pad on/off light will not come on.
artillery6
The on off light on the Powergear touch pad will not come on. I can not put the jacks down? Help on trouble shooting?
7 REPLIES 7
esyers
I had the same problem. I ended up finding a replacement control panel in a dealer's "junk box". He let me try before buying and it worked fine. Finding a replacement isn't easy. I'd suggest trying anyone to repairs/installs leveling systems and see what they may have removed and saved. Mine was not a perfect match, but it did solve that problem.
Good luck.
jerseyjim
In my coach, the jack pump is on the 12V starter battery...but the controller in on the 2 6V coach batteries. One time,I almost started taking things apart. Then....I realized the coach batteries were "off". Magic.
Hope this helps.
GPWayne
One more thing to try. Remove the control panel. remove the plugs and replace them. This will reset some faults and is easy.
artillery6
I have used the jacks since the surge power episode with no problems. The problem was fixed with a lighting control module that was paid for by the electric company.
2chiefsRus
could this be a left over problem from the electrical problems you posted about back in July? Have you used the jacks since then? Whatever happened with that problem?
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
Triker33
SYSTEM WILL NOT TURN ON, INDICATOR LIGHT DOES NOT LIGHT
PROBABLE CAUSE CORRECTIVE ACTION
COACH IGNITION NOT IN RUN POSITION
TURN IGNITION TO RUN POSITION
TRANSMISSION NOT IN PARK OR NEUTRAL
PLACE TRANSMISSION IN PARK OR NEUTRAL
PARKING BRAKE NOT SET SET BRAKE
CONTROL HAS BEEN LEFT ON FOR MORE THAN FOUR MINUTES, AUTO
SHUT OFF PUSH ON/OFF BUTTON TWICE
NO POWER TO CONTROL PIN #5 OF THE 6 PIN CONNECTOR ON THE CONTROL MUST HAVE +12 VDC
WITH IGNITION IN RUN POSITION, CHECK COACH FUSE OR BREAKER
GROUND WIRE DISCONNECTED OR SHORTED
PIN #1 OF THE 8 PIN CONNECTOR IS THE MAIN GROUND. TEST FOR CONTINUITY WITH
GROUND.
NEUTRAL SAFETY SWITCH WIRES SHORTED
JUMPER PINS #2 AND #6 AT THE 6 PIN CONNECTOR ON THE CONTROL.
IF JACKS OPERATE, REPAIR OR REPLACE WIRES OR NEUTRAL SAFETY SWITCH
PARKING BRAKE WIRE NOT GROUNDED, OR FAULTY PARKING BRAKE SWITCH
CHECK CONTINUITY BETWEEN PIN #1 OF THE 6 PIN CONNECTOR AND GROUND.
IF THERE IS NO CONTINUITY, THE SWITCH IS BAD, THE PARKING BRAKE IS NOT SET, OR
THE WIRES TO THE SWITCH ARE BAD.
FAULTY CONTROL IF ALL PREVIOUS CAUSES AND ACTIONS DO NOT APPLY REPLACE CONTROL
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
harold1946
I would first check for a blown fuse or tripped breaker. Then loose connections including the ground.
There is also a troubleshooting section in the owners manual.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
