Prepping RV roof for caulking
dshinnick
We have a 2005 motorhome with a fiberglass roof. I've been told by a couple of techs that it's time to re-caulk (Dicor) the seams on the roof. They mentioned cleaning the roof, so the caulk adheres well, but I'm not sure how to do that. Something like Simple Green? I was planning on taking a bucket of water&something up there and washing the roof with a soft bristle brush, and rinsing it well.
Thoughts? Suggestions?
thanks-
dave
19 REPLIES 19
TechWriter
DSDP Don wrote:
I don't know what type of coaches you guys have since you don't put them in your avatar, but next time you're looking at a Newmar, Monaco, Tiffin or any other diesel pusher, look at all the seems closely. They're all sealed with silicon that lasts for years.
Maybe on your 2014 Newmar, but the fiberglass roof on my 2001 Newmar was attached with something like plumber's putty, Sikaflex, and screws. There was no silicone involved.
I think some of the "silicone" products are actually rubberized silicone or a thermoplastic elastomer based sealant like EternaCaulk which looks exactly like silicone.
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
RedG
I know they use clear silicone rtv on all the body seams, but I don't think they use any rtv on any roof components.
2005 Newmar Dutch Star 4024 DP 370 Cummins
Towing my 2012 Malibu w/Blue Ox towbar & Patriot brake system
Bumpyroad
John Wayne wrote:
Are you sure it's silicone, dicor and the others are made in clear.
yep, clear urethane based on mine.
bumpy
John_Wayne
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
Deano56
What makes your statements incredibly wrong, is that you can look at any coach on a dealer lot and see silicone, especially over each window!!!!
i have looked at plenty of coaches, including Newmar
DSDP_Don
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
Bumpyroad
Deano56 wrote:
the only silicone I'm seeing on coaches is patch work that someone has done after the fact. Silicone will not take the long haul, if it would, car manufacturers would be using it in the joints too, its not good in direct sunlight continuously
X2
Don't see any on my RV.
bumpy
Snomas
John Wayne wrote:
If you have a white roof just clean the area with acetone get some 4' wide Eternabond and it will be the last time you have to do it.
X2 on Using Eternabond!!
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
Deano56
RedG
There's a video on this page.
John_Wayne
Security by Bentley
God Bless
KF6HCH
DSDP_Don
I see some don't like silicone, but go out and check EVERY joint on the sidewall of your coach! From the windows to the moldings to the wheel wells, it is covered/sealed with silicone after it's painted.
For the past ten years many coach manufactures have been using eternabond to seal the front and rear caps to the main portion of the body.
Don & Mary
TechWriter
Depends a lot on how your fiberglass roof is constructed. On my Newmar, the roof is a big rectangle of fiberglass that is overlapped and glued & screwed onto more fiberglass.
My roof had some "warped" fiberglass where water had entered so I had to re-glue & re-screw these spots first.
Anyway, I used a sharp wood chisel (be careful) to remove the old caulk and cleaned with an abrasive pad soaked in 409 cleaner. Finally, I wiped the seams with acetone.
Here are photos of my repair.
DISH TV for RVs
hooligan
Big concern with silicone is that once it is used, nothing will stick to that area again if the silicon needs to be replaced.
Hooligan U.S. Coast Guard Ret.
2016 THOR Siesta Sprinter 24ST Diesel
2008 SUZUKI Grand Vitara TOAD
1 Pug "Lily", 1 Newfoundland, "George"
1972 MotoGuzzi Eldorado
