Question on water pump?
Branson_N_Tucso
Still Can't locate the fuse for the power on water pump. However now it seems that the city water entering Emmy coach is not only going in but also leaking into the fresh water tank. This seems to just started when my pump went out.
Is there any coordination between the to.
Need to know before I start going into the intake valve.
Thanks for any information
Again, it is a Sure Flo water pump with 3 separate on and off switches in the coach.
4 REPLIES 4
magicbus
wa8yxm wrote:
Sounds like a failed check valve and you may wish to order a new pump.
My thought exactly.
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
wa8yxm
Old-Biscuit
3 switches for pump...then it has a latching relay
Pump switches connected to 'ground' so they make up circuit thru latching relay
Locate latching relay and check for DC to it
Fuse could be at pump or at relay
As for fresh water filling while using city water
Either the 'Fill Valve' (if used) is leaking thru
OR
Pump Internal check valve is not closing and allowing backflow thru pump
Jim
Fuse for that device is usually within a few inches of the pump. Find the pump, and the fuse will be very close. Probably in the red wire.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
