radiator
backhoemike
Radiator is rotten, any ideas on where to find after market radiator for 1995 newmar London aire, Spartan chassis , I emailed Spartan and no reply today. I the road salt must have eaten all the fin's away it looked like it was just dirty and I touched the fins and it is just rotten. Re-core it ? New one? any newer model radiator that will fit and has anyone had to change themselves...
13 REPLIES 13
Sully2
mpierce wrote:
Look into recurring. Take it out, and they can measure the radiator part. Then, they can order that. They then take the top and bottom off your old radiator, and put them on the new core. Usually much cheaper, and faster, than buying OEM.
RECORING!
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
Sully2
Tom/Barb wrote:
Always call first.. 1-888-879-5671
AFFIRMATIVE.!!! Get ahold of service and see what they tell you and then get on the line with tech support and find out just who it was that made it for Spartan.
2002 Jeep Liberty
2016 Ford Escape
mpierce
backhoemike
update mine had plastic tanks also and couldn't be re-cored. But found a good local shop to build me one for 800.00 anyone have trouble in Western Ark. Or Eastern OKLA. give me a shout I can hook you up , I pulled the radiator myself and hopefully it will all go back like it came out and I will be Happy thanking the RV gods for letting this happen close to the house, out on the road you wont have time to do your homework and at the mercy of these thieves...
ferndaleflyer
I think I paid around $1600 a couple of years ago----everyone is proud of DP parts.
RayChez
Snomas wrote:
I had a Spartan authorized repair center in Denver replace my radiator w/ a new one (in 2009) they ordered from Spartan. Took several weeks to get the job done. Two yeas later a rock hit the rad and put a hole in it and I had a repair shop remove and repair the hole. I recently had a heater hose break and now have replaced all the heater hoses. I feel like I can't get away from heating/cooling problems w/ this Spartan chassis.
Just wondering: Are these side radiators or rear mounted radiators.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
Dutchstar02
Be thankful you don't live in Canada. The rad went on my 02 Dutch Star (Freightliner chassis) and they wanted $3300 just for the rad - installation extra. I found a specialty rad shop that could do the work but there were some issues. The rad could not be recored because it had plastic sides so a new one was required. Turns out the rad is from a Volvo truck. The new one has 4 cores while the old one only had 3 so the rad is essentially 25% larger - cost $1800. That was the easy part. Labor for a side rad is 10 - 13 hours. Total cost was $3500 out the door. If I could have made it back to the States without any worries I would have done the repair there - the cost for parts in Canada is sometimes double that of the US and tax in Canada (13%) is for the whole bill (including labor) - I know that Arizona doesn't charge tax on labor.
Bill
02 Dutch Star DP 3852
Toad: 03 Explorer
JR45
I got mine here installed by Quinn Cat in Calif.
http://radiatorsupplyhouse.com/
JR
2006 Country Coach Inspire 360 40ft Genoa Designer Series Cat C9 Samsung 197 RR
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
Toad--2011 Ford Edge Sport, Air Force One
:C
backhoemike
guess its time to get it out and then go do my home work , I feel your pain on the rocks, I wired rabbit wire to the bottom to prevent it seems to have worked..but radiator is so hidden you can wash or clean
Snomas
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
sch911
Any decent local radiator shop should be able to re-core your radiator...
OEM Auto Engineer- Embedded Software Team
FIRE_UP
backhoemike,
The first thing many guys think about when their diesel coach or, even gas coaches radiator goes south permanently is, head to the manufacturer. It's a natural reaction. Here's a short story. I had a leak in ours. Our coach is an '04 Itasca Horizon, 36GD with the C-7 330 HP CAT engine. The leak was an on and off, leak. Meaning, it only leaked a tiny bit and then stop for a month, then do it again, then stop for a month.
But, I'd been hearing about how clogged up the fins could get from the slobber tube and dust and debris. So, I did a good thorough inspection and, found out about 35% of my CAC and radiator were completely clogged. There was no way on this earth I was going to be able to clean that stuff thoroughly in the coach.
So, out came both the radiator and, the CAC. Well, the radiator was an aluminum core with plastic tanks. The lower left corner was deteriorated badly. Well, that meant a phone call to Freightliner for a replacement.
It's a good thing I was sitting down when the Freightliner person told me the price. A whopping $1,780.00 and, the closest one was in Georgia. We lived, at the time, in the San Diego area. They said it would be around 7-10 days to get it to me.
So, just for grins, I headed down to a local radiator shop in the town next to where we lived. It's good sized radiator business. I showed mine to him and asked if he could repair it. He pointed to a shelf in his facility that was completely loaded to the brim, with aluminum radiators. It's like that because about 99.99% of the time, they are not repairable.
I said, "crap". I said then, well, I guess I better go take out a loan for the one from Freightliner. His reply, he... no, you don't have to buy one from them. He took some quick measurements of mine and, headed to the computer. He located an exact replacement, less than 24 hours away. He said, "I can have it here tomorrow by noon. I said, "OK, how much"? His reply, $1,250.00, out the door!!!
And, he said, "this one's made of copper/brass". That means, it can be repaired, if and when it's needed.
So, the moral of the story, check around with your local radiator shop. The one he got for me fit exactly right, inside the steel frame that the aluminum one sat in, to a tee. I'd do it again in a heartbeat.
Scott
Scott and Karla
SDFD RETIRED
2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
Tom_Barb
2000 Newmar mountain aire 4081 DP, ISC/350 Allison 6 speed, Wrangler JL toad.
