Rear AC not working
srx-6
I have a 2009 Monaco Camelot, the ac in the bedroom has quit. I replaced the start capacitor today, the motor runs but the compressor will not start. I can hear it trying to start but after a few times the breaker trips. I replaced the breaker a few weeks ago. I have also taken a soft hammer up and "tapped" the compressor a few times (have seen this work with refrigerators), still will not run. Looking for any suggestions to try before I start pricing a new unit. Thanks for any help.
JB & MB
2009 Monaco Camelot 42PDQ
2008 Jeep Wrangler
4 REPLIES 4
srx-6
Thanks fellas
Pretty sure I got the wires on right, took a picture before disassembly. Did not notice any melted wires. So now start looking for a sale on Dometic ACs
JB & MB
2008 Jeep Wrangler
Executive45
dougrainer wrote:
If the capacitor was bad, it would NOT cause the breaker to trip. The fact that it trips the breaker points to a locked up compressor OR the 3 wires attached to the Compressor have melted and shorted. Check those wire connections. If GOOD, replace the unit. If melted/corroded, fix the wiring and retest. Doug
What Doug said..unless, or course, you messed up putting the wires back on the correct terminals.....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
dougrainer
Triker33 wrote:
Did you replace the start capacitor on the motor or compressor.
Both are in the same area.
If it was the compressor one. Then start your search for a new AC.
Triker33
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
