Rear View Camera
jvowell1
Any help on troubleshooting rear view camera on a 1996 Damon Intruder. Ford chassi if that matters. Black and white Voyager. Monitor seems to be working, but no picture (just white snow). I ain't got a clue on how to check the camera.
5 REPLIES 5
Clay_L
My cat used to unplug the connector on the back of the monitor from time to time. There was also an unused second camera switch on the monitor that somehow got moved to the nonexistent camera position once.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
crasster
First check is to check the coax by opening the housing. Next is the tap tap on the camera once inside while somebody watches the monitor. May be as simple as a coax/power issue, or as complex as a bad camera or tiny wire fracture.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
jvowell1
I have owned it a couple of years and it is always on with the ignition switch. I just went to use it and no image on monitor.
zigzagrv
Not familiar with that particular model, but it may be set up to operate only when in reverse. Turn on ignition and put the mh in reverse and see if it comes on. Also, may be a switch to have it come on just in reverse or on all the time. Also it may have more than one camera input on monitor. If it does, move it to one of the other inputs.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
2013 Ford Edge toad
rv2go
If all fails here, get in contact with RV Cams. They were of help to me.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
