refridge goes to gas
Your_Pal
My refrigerator keeps going to gas. I checked the fuse in the back and it was good. I'm plugged into shore and the "salesman switch" is on. I had the inverter off and nothing. Turned it on and nothing. what else should I try?
Thanks
Rico
8 REPLIES 8
zert800
I had the exact same problem, and I did slap myself. Doh!!
go hard or go home
Executive45
Thanks for the update..now go slap yourself up the side of your head....:B....Dennis
ArchHoagland
Thanks for the follow up letting us know what the problem was.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
Your_Pal
Bath GFI was tripped.
thank you for the help.
Rico
dougrainer
Brand and Model of refer would help. Doug
Your_Pal
The fuse behind the fridge was the first thing i check. All my breakers are good. I did not find another fuse in the fuse panel for the fridge. I will do the blow dryer check when if stops raining.
Thanks
Rico
sch911
First understand that your fridge has two operating modes:
1. LP Gas and 12V DC(for electronics).
2. 120V AC (shore power) and 12V DC(for electronics).
So assuming you're plugged into shore power and have a charged house battery it should run on electric. If not check for both sources of power at the fuse panel and breaker panel, and behind the fridge itself.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
wolfe10
Salesman switch is 12 VDC. Nothing to do with your issues, since it works on propane.
Many 120 VAC outlets for refrigerators run through a GFI outlet. Check in bathroom, etc. to see if one is tripped.
Plug a 120 VAC light, hair dryer or other appliance into the refrigerator 120 VAC outlet and you will know if/when you have power there.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
