Refrigerator question for you class A campers
steveandjil
We have had a Winnebago View class C for about 5 years, and a 5er for the decade before. We think at times of a larger class A for part timing in retirement. Many have commercial refrigerators. How do you keep your food cold when camping in a no hookup CG such as a national park. Can’t run the generator 24/7.
Thanks,
Steve
Steve Schwartz
2015 Winnebago View
26 REPLIES 26
Bill_Satellite
DutchmenSport wrote:
or else the refrigerator is plugged directly into a generator.
No, the coach is plugged into the generator (or the generator is built-in) and the generator provides power to the fridge and multiple other sources in the RV. Depending upon the size of the generator it can power everything in the coach including the A/C's.
Can't we all just get along?
RLS7201
Note all the thrashing about with extra batteries, inverters and solar to have a residential refrigerator. The old absorption refrigerators performed well when install properly. Read the manufacturer's installation manual, it's an eye opener. Norcold did the RV word an injustice with their lesser materials and poor welds, causing fires.
How much room do you need in an RV refrigerator? Seldom are you far from a store.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Gonzo42
OUr View is our first RV but we are toying with the idea of a smallish Class A. I am a bit concerned aout the handling and towing power. Our View has been upgraded to a 7 1/2 cuibic foot unit running auto with shore power and propane. It would be nice to have a 3-way reefer.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
DutchmenSport
If you have an all electric residential refrigerator in your camper and don't have shore power, the only way to keep the refrigerator running is with an inverter and a battery bank, or else the refrigerator is plugged directly into a generator.
In our world as it exists today, you have two methods to keep your batteries charged; solar or generator.
If you don't run your generator to keep the batteries charged, solar is the only other method. Pick your method: generator or solar. There's really no other short-cut.
wa8yxm
I have a RV type "Absorption cooling unit" (Refrigerator) this uses HEAT to Cool believe it or not so it can run on electricity (About 325 watts in my case which is not at all efficient) or Propane.. ONly moving parts are the gas valve and fluids inside the cooling unit (Gas and liquid) Just put a new cooling unit on it after 14 years and change last Oct. (OUCH).
Now it does use 12 volts for control and ignition but it can run a long time on a full tank of propane and a full battery bank.
I also have a 2nd Freezer. this is one of the high efficiency Compressor units (Engel) Both Dometic and Norcold have offerings in this class. Mine is a chest freezer and draws a great whomping 36 watts (3 amps at 12 volts) when running. I have over 500 amp hours of battery so you get the "how long". Even a single pair of GC-2 (220 amps hours) around 3-4 days
At one time both D and N had full size RV refrigerators using this technology but I'm finding them harder to track down now.. 35-45 watts the compressor is what I call a Danfoss class (look it up) may be a Danfoss or a competitor's but that class.
However when on the move.. I burn propane.
wildtoad
You planning on being out in the Arizona sun in the summer and run fridge on batteries? You OK inside a MH with no AC?
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
Bruce_Brown
Moderator
Moderator
Today's modern refrigerators use so little electricity compared to the older ones it seems to not be an issue for most.
A few years ago I put a new cooling unit in our LP fridge. If I were doing it again I'd just put in an electric one.
We recently did that in my buddies off-the-grid hunting camp. The new electric with limited generator usage works much better than the propane one we took out.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
Dale_Traveling
Thanks,
Steve
A battery bank properly sized to support the house loads for 24-36 hours, energy conservation, a few 100 watts of roof solar helps reduce generator dependency, generator use to recharge the bank in the morning and evenings.
2006 Hurricane 31D built on a 2006 Ford F53
Lwiddis
Why think only about a generator? Solar recharging isn’t experimental or a toy. Most days you’ll be completely recharged with adequate system...batteries, controller, solar panels and properly sized wire. Start with an energy survey to determine your amp hour needs.
ScottG
Sure - with enough batteries 😉
steveandjil
Yup meant residential. So the batteries are just run through a big inverter I assume. Can you go a day between generator runs in hot weather?
Steve Schwartz
2015 Winnebago View
ScottG
Lots of batteries and I think you mean residential, not "commercial".
