removing the 3m film on the front of a class a
campingman55
ok i have the 3m film on the front of my coach i can get the film off but what do i use to get the glue off with out hurting the paint i have tryed gas and wd40 nothing is touching it
2005 vectra 40fd motor home and wife and our 2 pita malties and a mini poodle
11 REPLIES 11
kdk
Sent you a PM, call me
06 Holiday Rambler Ambassador
2016 Ford Explorer twin turbo
Bird_Freak
From a old painter. Never use brake fluid on paint!!
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
mikestock
I did this job a couple of years ago. I found that acetone worked best to remove the residual glue. I did, however, have a couple of decals under the film, so I used polishing compound and a lot of elbow grease to remove the glue on those decals.
The acetone left the paint clean and shining with no damage.
Ivylog
$150 and 6 hours tells you how cheap and poorly attached film Winnebago uses.
Since you have a Winnagago I'd give the # above a call. Took more than 8 hours to remove just the film using a heat gun and plastic razor blades.
Upgraded with a 08 HR Navigator 45โ€™...
emiddleb
I've been using these to remove the glue after removing the film off my Vectra...
Paint & Graffiti Wipes
works very well.
2004 Winnebago Vectra 40KD
Roadmaster Tow Dolly
rv2go
I had the film removed by CDI, the paint contractor for Winnebago in Forest City, IA. I would contact Dave at dave_cdi@wctatel.net or call (641) 585-5900. He might tell you what they use. I was in and out in less than 6 hours. $150. Great job.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
Executive45
donn0128 wrote:
Mod notified
Duplicate post. Here's the other one.
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29473216.cfm
To the OP: Forum rules prohibit duplicate posts in various forums. Pick one or the other and delete the one you don't want....Dennis
Executive45
Goof Off or GooGone. Both work as well as can be expected, won't hurt the paint but both take a lot of elbow grease....good luck...Dennis
cableguy574
Try Goof off, it work on mine
2008 National Pacifica V36a
2014 Jeep Wrangler /Brake Buddy
JUST Me & My wife & dogs ๐Ÿ™‚
FMCA 387898
A member of NUTS
brianj1945
xyzlene , not sure of spelling
i also have used brake fluid on a portion worked great, just test a spot 1st to make sure it doesent effect your paint
brianj
brianj
2011 georgetown 280 ve
2010 wrangler toad
WAFlowers
Heat gun. And lots of elbow grease.
Bill and Willemina Flowers
George, Sammy and Teddy (the dogpack)
2008 Tiffin Phaeton 40QSH
2005 Keystone Monata 3400rl (5/21/11 to 9/9/17)
(Was in a 2000 Coachmen Catalina Sport 220RK)
