โJun-03-2014 06:41 AM
โJun-18-2014 05:03 AM
rodsterinfl wrote:
I only run it on high. I learned quickly that it will freeze if I don't. It can run all day on high but for some reason, freezes up after so long on low. The fan runs on high while the temp is at one-half. Good checking point though. I've been reading about a difference in more recent AC units being noisier than older ones. That too could have an impact. My current coach is an '06 with a Penguin unit. Now there is Penguin II.
I did change my air distribution unit to the new style with the five direction airflow instead of the all front/back. That was a much needed change for comfort at night or even when sitting.
โJun-17-2014 05:12 PM
โJun-17-2014 05:00 PM
โJun-17-2014 04:51 PM
rodsterinfl wrote:Make sure the ND one was on high fan.
5 as opposed to my 62dB/62dB/61dB in my non ducted 26' system. Granted there is a .5-1.5dB difference.
โJun-17-2014 04:48 PM
โJun-17-2014 03:44 PM
rodsterinfl wrote:As one who has had both, I can testify the ducted is MUCH quieter.
Is ducted cooling really quieter?
โJun-17-2014 03:32 PM
โJun-17-2014 01:06 PM
โJun-17-2014 12:41 PM
โJun-06-2014 10:35 AM
โJun-05-2014 03:49 AM
โJun-04-2014 07:36 AM
โJun-04-2014 03:33 AM
rgatijnet1 wrote:
It seems to be that most ducted AC units are quickly installed at the factory without the benefit of the installer taking his time to actually seal all duct leaks at the unit.
My AC unit was marginal until I removed the cover and, using AC duct seal, was able to actually seal the ducts so that the cool air actually went where it was supposed to go. After doing that, I am glad that I have the ducted AC system and the airflow is sufficient now to distribute the cool air throughout the coach.
Porsche or Country Coach!
โJun-03-2014 09:03 AM
