Roadtrek Tail light doesn't work
RT170P
Aloha all:
So our 2007 Roadtrek 170 (MJ 🙂) has a taillight (passenger side) that is out. Immediately thought bulb, so I changed that...still didn't work (later confirmed the original bulb and replacement are good), so I went to the fuse box...fuses are good too, which leads me to believe the problem with the wiring; is that a logical conclusion? I know there are many locations where wiring will have been run/spliced together; does anyone have a suggestion of where I should look specifically to isolate the problem for the passenger side taillight? Mahalo in advance.🤙
Mike
4 REPLIES 4
Community Alumni
Not applicable
You could wait until your dash lights go out and then you will know you have no tail lights at all. Trust me it's the ground wire. Do you have a wire tester (PHOTO #1) Clap to the vehicle's metal body and stick point into the wire. (not hand or fingers) If you have the Bulb in and lights on, doing this should turn the light on unless the ground is bad. If you had any work done say to your trailer tow hitch with trailer lights that may be the issue. Trailer lights may work but, one of the vehicle lights goes out. Re-due and check wiring.  I think the Bulb is a "1040" Which lights up when stopping, Running lights are on, or blinkers are on. Let's us know how it works out for you.  Good Luck and safe Travels.
RT170P
Thanks to you both for the suggestions; besides bulb and fuses, the ground wire sounds a likely culprit. 🤙🏼
Mike
MNtundraRet
Navigator
Navigator
You most likely have a bad ground on the passenger side on rear right. Check for a loose wire or rusted ground wire.
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
bid_time
Nomad II
Nomad II
Yes you need to check the wiring. Check for 12V power at the light itself and especially check for continuity (all the way back to the battery) of the ground. There is about a 90% chance (IMO) that the problem is the ground.
