Oct-24-2014 07:24 AM
Oct-25-2014 10:36 AM
Oct-25-2014 07:42 AM
Oct-24-2014 02:48 PM
infogeek wrote:
Pogoil, they make several types, do you remember which one you used?
On the phone the RV man said he doesn't recommend coatings because all of his customers that used them have said they flaked off and didn't last; and he mentioned that having moisture under the rubber would cause them to fail. I don't know enough about rubber roofs and coatings to know if that's true or not, hence why I am here.
I know the RV isn't going to last forever, but if I could get 5-10 more years out of it without breaking the bank, that'd be great. I don't mind the cost of maintenance but $6K is kind of steep for me right now (I have an antique home money pit eating most of my resources at the moment).
Oct-24-2014 02:46 PM
Oct-24-2014 01:40 PM
jolooote wrote:
Do U have a Max Air roof vent cover over the vent that leaks? I had this situation. I found that when I removed the MaxAir cover it stopped leaking. The cover is mounted by drilling holes into the sides of the vent rim. I had resealed around the vent as you did. I inadvertantly built a 'Levy' of lap sealant around the outside of the vent edge and when it rains there was a little lake or mote of water all around the vent that got deep enough to leak into the drilled holes for the MaxAir cover.
Oct-24-2014 11:55 AM
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
Oct-24-2014 09:31 AM
infogeek wrote:
RV guy was just here. Can't see any obvious leaks but says the rubber is checking. Thinks it's getting porous and should be replaced. He thinks scrubbing and prepping to apply a coating will make it worse, and isn't sure it will stick (like duct tape on a powdery surface is how he put it). I did try some Eternabond at one point for an emergency patch and that did not stick despite cleaning and rollering it hard, so maybe he has a point there.
RV Daytrader: yes, installed roof vent/fan.
Oct-24-2014 09:03 AM
Oct-24-2014 08:50 AM
Oct-24-2014 08:47 AM
infogeek wrote:
I'm hoping the RV man can do the seal test. If not, where do you have those done? I'm willing to do it; I just thought I had found and fixed the leaks, but have been proven wrong. 🙂
Oct-24-2014 08:28 AM
Oct-24-2014 08:05 AM
Oct-24-2014 07:53 AM
Oct-24-2014 07:51 AM
