Despite cleaning with acetone and scrubbing the Eternabond still not stick, I'm not sure if the caulking is either. Also where the radio resides need to remove it and fix the deck underneath due to previous leaks. I'm not sure what the PI put on this but nothing wants to stick up front. In the back I've used Eternabond successfully with no issue's.
I've thought along the lines of just cutting back past the radio antenna and buying a new piece of Alpha superflex and using Eternabond on the joining seams. Bad idea?
The back 25ft or so of roof itself is in great shape still and no other leaks. Go figure nothing wants to stick up front even the paint on the hood. I'll have to redo the inside also... with the Styrofoam that'll be a blast!
2005 Jayco Escapade 28ZSLP (3500 Chevy chassis)
