His roof is probably a EDPM rubber roof. It's a sheet of rubber, black on the bottom with a white top layer. The sun and weather takes it's toll and the white layer wears away. Doesn't mean the roof is shot or that it will leak but it is getting old. If he's up to it search for Liquid Roof/Liquid Rubber. It's the same EDPM rubber as the original. A 2 part system you mix then apply to the old roof, after it's thoroughly cleaned. It's a messy job but not that hard. He'll end up with a brand new layer of rubber on top bonded to the hold roof. It comes in pure white, Liquid Rubber, and off white, Liquid Roof. They're identical compounds, Liquid Rubber marketed for commercial roofs, Liquid Roof for RV's.
