Sep-13-2017 08:53 PM
Sep-15-2017 06:24 PM
Sep-15-2017 05:57 PM
enblethen wrote:
Photo shows main breaker 50 amp with retainer.
The two black wires on main is a big question.
Is ther a ground buss behind the right column of circuit breakers?
Do you have an inverter?
Sep-15-2017 05:33 PM
time2roll wrote:
What do those two black wires off the top feed? Are they hot with no breaker?
Seems odd.
I think those are the in-feed terminals if you were not using a main breaker.
Sep-15-2017 05:10 PM
Bud
USAF Retired
Pace Arrow
Sep-15-2017 05:02 PM
CA Traveler wrote:
rhagfo,
Read the first post. Since the circuit is now for a RV and no longer used for a hot tub it's not a code violation.
Sep-15-2017 04:41 PM
CA Traveler wrote:
Try this: Turn off all RV CBs, power on to the RV. Then at the RV panel turn on the main CB and then each remaining CB one at a time. This may isolate the failing circuit.
Sep-15-2017 04:30 PM
Sep-15-2017 04:12 PM
Sep-15-2017 03:58 PM
Sep-15-2017 02:30 PM
Sep-15-2017 02:20 PM
Sep-15-2017 01:49 PM
Bud
USAF Retired
Pace Arrow
Sep-15-2017 08:22 AM
Sep-15-2017 08:02 AM
CA Traveler wrote:mike brez wrote:A 120/240V 50A RV plug is not the same as the older 240V 3 wire dryer plug. The 50A RV circuit is the same as newer 120/240V 4 wire dryer but the dryer circuit may be less than 50A.
With that being said just out of courisity if the dryer and rv have the same readings at the female end I take it that the single 240v for the dryer and the split 120v lines for the rv it is all in the wiring on the inside the dryer or in the rv panel?
The 20A and 50A RV plugs are in fact common household plugs. The 30A plug is unique to RVs.
You definitely want the 120/240V 50A RV plug. You can also have a 50A GFCI on that circuit. If the GFCI trips then you'll need to resolve the rigs ground fault. 50A GFCIs are more common for pools, spas, etc.
Sep-15-2017 07:34 AM
