RV battery charger tech advances in simple devices?
burlmart
i have separated my 2 RV batts and run a wire from chassis + term to the house batt compartment area. now can check voltages w/ multimeter and charge either batt from one spot.
have used the walmart charger above for 20 yrs - it says fully automatic. it looks to be the schumacher below.
http://www.sears.com/schumacher-ps-2100ma-100-amp-15-amp-2/p-SPM7450291003
my question is if there is much difference in the tech inside these 2 devices after 20 yrs?
2005 Trail Lite 213 B-Plus w/ 6.0 Chevy
2 REPLIES 2
WesternHorizon
There are credible claims that the military uses desulfators
http://www.impactbattery.com/blog/2013/02/battery-desulfators-do-they-work/
The BatteryMINDer Charger/Maintainer/Desulfater - 12V, Model# 2012
http://www.amazon.com/gp/product/B005EKY1EM?psc=1&redirect=true&ref_=oh_aui_search_detailpage
claims to desulfate. I have one 2012 unit with a splitter
BatteryMINDer SmarTECHnology-Y Multiple Battery Connector - Model# 210AY
that charges **BOTH** the chassis battery and the house battery when I am home. The two batteries are the same type (AGM), different brands, and similar but different capacities. The batteries are NOT a matched pair.
I have another 2012 charger that charges BOTH of my dirt bikes whenever I am not riding them. Again, the two batteries are the same type (sealed lead acid), different brands, and similar but different capacities. The batteries are NOT a matched pair.
The point here is, I charge and allegedly desulfate four different batteries with two chargers.
But check the specs carefully. The 2012 is versatile but it does NOT handle gel cels. For total versatility, you have to move up to the 12248 which is much more expensive.
Maybe that little blinking blue desulfating light is a placebo, but I have been happy with this setup so far.
donn0128
Probably. Most newer battery chargers have "smart" controlers. Meaning there is a chip inside that reads and monitors battery voltage. Most older chargers had a simple timer that turned on/off the charger.
