Saftey Chains on Tow Dolly
RJsfishin
Dolly towing not much more difficult than a tow bar, except for hookin up the safety chains.
I'm thinking of an easier way so as to not have to crawl under the toad.
What about just an extra set of straps w/ big snaps mounted to both ends, thrown over the first ones ?
I think code calls for chain, cable, or straps, so seems this would qualify. Or they could be chain, kinda like a set of tire snow chains
Whatcha all think?
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
16 REPLIES 16
Leeblev
What are you towing? On all of my vehicles, I have a tiedown hole at the front of the frame on both sides. My safety chain fit through that hole without me having to do more than sit on the towbar frame and lean over. When I first got my dolly, I knelt down on the ground in order to fish the chain through, but soon learned that I didn't have to do that. The only thing I have to do is take the "D" ring off of the chain to fit it through the frame tiedown hole.
The safety chain is the safest setup, although cables and proper straps are ok. My chains were rated for 6,000 lbs and came with my Roadmaster.
Again, after learning that I didn't have to crawl under or kneel on the ground to connect my safety chains, I was happy with that setup.
I changed toads to a rear wheel drive and no longer have my dolly. That is the only reason I got rid of it though. I now tow 4 down with a towbar. I'm happy both ways.
Lee
2001 36' Kountry Star DP
enblethen
Some trailer dollies come with the web style straps that go over the tires like what the snow chains do. They are then tightened with a ratchet style device.
look through this manual from Roadmaster. It gives some incite.
Dolly manual
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
