Screws in the ceiling?
C_J1
I need to replace a ceiling-mounted CO detector and I can't find any current models that fit the existing base plate, so it looks like I have to attach a new base plate to the interior ceiling. The ceiling appears to be some kind of padded vinyl. Can I just use screws to attach the new base plate and detector?
2011 Itasca Sunova 33C
13 REPLIES 13
C_J1
I guess screws are winning the poll. Thanks again.
MountainAir05
When we replace both of ours. WE use screws. One was close to a light and I could put a screw clip also on that one. Been that way for the past 8 years. Ready for a replacement .
mike_brez
I only see one option......screw it on. Or you will just be making problems for yourself down the road.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
ScottG
Yes, you can just use screws.
wa8yxm
YES .. If you are really worried however I will design you a something
Take the OLD detector and lay it on a sheet of wood I'd go a bit thicker than quarter inch, perhaps 3/8.. Mark and cut out the circle.
Using the ORIGINAL screws and holes mount it,, then mount to it.
However you dont' need to do that
NOTE: Atwood detectors, the round ones, Really Kidie in disguise.
viajante
I am surprised that a CO detector would be on the ceiling. They are supposed to be down low, as CO sinks. Are you talking about a smoke detector ?
pigman1
dougrainer wrote:
There is ALWAYS 1/8 to 3/16 wood luan behind the Vinyl. Just use regular 1 inch wood screws. Doug
Yep, and the screws wont let the weight of the detector separate the ceiling material from it's backing as you bounce down the road.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
doxiemom11
Our is mounted on a wall. Just checked because I wasn't positive, but best results are when mounted about 5 ft above the floor.
C_J1
Sounds like I have at least three good options. Thanks to all who replied.
dougrainer
stickdog
Heavy duty velcro.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
evanrem
Command strips worked for me. Put a few on there.
DutchmenSport
Double sided sticky tape, that fat stuff that's impossible to remove once you stick it on.
But, if you use the exact same screws that hold it on now, you'll probably be OK. If you do have to get a new screw, don't get anything longer than what's currently there.
I'd do the double sided sticky fat tape myself.
