slide out leak?
fizikpal
My 2002 Shasta Cheyenne developed a leak in the bottom of the slide out that only occurred while driving. It appears that the outer seal of the slide out (which was original) is shot and I could see some daylight in the bottom corner of the slide when it was fully in.
Went to get it replaced and am seeing a little bit of daylight again. Not sure if that is ok. Have not driven it in the rain yet.
Thoughts.
The Lynch's
2002 Shasta Cheyenne 308
TOAD: 2003 Honda Civic
Sterling Tow Bar with Brake Buddy
1 REPLY 1
consumeratlarge
There are adjustments that could be slightly changed to get the bottom tighter. Verify that it is stopping at the top because it is completely flush, and if you still have a gap at the bottom, that's 'just' an adjustment. Looks like a little handyman skills and patience would be required on the ones with hidden cables, but it can be done. Outside edge to wall seal should be the easiest surface to seal by yourself. You could even use some foam stick-on insulation tape temporarily to stop the water until you get it straightened out.
Coachmen Pursuit 31BDP 2013, 300w solar, 1200w sine inverter, In-motion Winegard Dome sat. ant., L.E.D. lights, P2 brake controller, Yamaha 250 on back carrier, or pulling Stehl dolly with Hyundai Santa Fe
