Slide stuck in out position
Gone_fishing1
The slide on my Gulfstream is stuck in the out position. The motor runs but nothing moves. Can I fix this myself or should I call someone who know what they are doing?
Bob
2016 Itasca Sunstar toad 2006 Dakota.
5 REPLIES 5
klutchdust
Bedroom slide?
USAFBILL
If the motor is running perhaps you have a missing/broken sheer pen that connects the drive rod to the slide frame...Very easy to determine if you can see from the underside, if the bottom is open
2003 Cougar 285EFS
2000 Chev 2500 Ex Cab
Gone_fishing1
Not a super. It is just 26 feet.
ronfisherman
Moderator
Moderator
Bob
Is this a Super C with hydraulic slides?
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
Nicholsfamily05
Have you tried the manual retract.
Should be a spot on the opposite side of your trailer where you can access the mechanism. The factory should have provided the tool to operate it in one of your storage compartments.
Our TT was under the master bed but in our FW it is mounted to the wall in the Passthru storage.
Usually the area that has the crank shaft to bring it back is marked, not very clearly but some type of marking is there.
2016 Ram 3500 4x4 Big Horn Crew Cab, SRW. Cummins Turbo Diesel Automatic 68RFE Trans
50 gallon diesel Transfer Flow tank with the Traxx 3 system.
2017 Sierra FLIK 5th Wheel
42' Front Livingroom, 15K
Hydraulic level up system
