Slideout
Having_Problems
Hi
Since I am unable to retract my slideout with motor or manually with a wrench would it be possible with some help to physically push slideout all the way in????
Help
Thanks
5 REPLIES 5
Having_Problems
Problem solved
Replaced slideout motor with attached gearbox,gearbox had failed
Slideout now works better then ever
Thanks for all your suggestions
Having_Problems
Motorhome is a Fleetwood 2006 Jamboree 23 e
Slideout system is a 2 rail Powergear Electric System
Motor has brake to release & also to lock slideout from moving once retracted
Just don't know if anyone has had experience in physically pushing a slideout in
Slideout has a couch & wardrobe
Thanks
SidecarFlip
ronfisherman wrote:
Every slide is different. But if you and others push on slide to retract it. Make sure that everyone pushes where there is inside support. This should avoid damaging siding.
.... and then you need to secure it to keep it from coming back out as you drive down the highway..,..
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
ronfisherman
Moderator
Moderator
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
hamrs_62
depends on which one you have,on mine if you have your motors disconnected, yes, then you need to use something to block it from sliding back out
