How to power off residential fridge
AikenRacer
I just took our MH in for repairs. Will probably take a week. Emptied the residential fridge as the mh will not be plugged in or generator used. I think I need to shut off the fridge but I don't know how. I cannot get to the rear of unit due to it's installation. I shut off the main coach switch in the battery compartment but power still remains on the fridge. I really want the fridge off so it won't run down the batteries. I'll call Thor tomorrow but figured one of you out there knows how to do this. Thanks!
2012 Tuscany 42RQ tag
2005 Silverado 2500 w/ piggy back golf cart
13 REPLIES 13
AllegroD
dougrainer wrote:
1. TURN OFF THE INVERTER! There is NO reason to have the Inverter ON when in for service. Leaving the Inverter ON will just cause your coach batteries to go dead in a few days.
2. Most Residentials have a specific sequence for completely turning them OFF. The reason is simple, IF you had to turn the refer ON each time you powered the RV up, then in a 120 power Interuption, you would ALWAYS have to make sure you turned the refer back ON to prevent food spoilage. SAME concept for your HOME refer.
3. You usually have to push at least 2 buttons and hold for so many seconds to turn the refer OFF.
4. READ the refer owners manual, it will tell you how to turn it OFF and ON. BUT, this is a foreign concept for lots of people especially RV owners:S Doug
^^^^ This.
OP,
BTW, you say you cannot get to the plug. Did you completely seal the outside vent? Though somewhat sealed, I can take out some insulation so I can get to the back of mine.
dougrainer
Two_Jayhawks
Well, I'm sure you already investigated this but I have a on/off control on the exterior buried (very small) in the controls around the water/ice dispenser.
Bill & Kelli
2015 DSDP 4366 pulling a 21 JL Unlimited Sport
2002 Safari Zanzibar 3906 gone
1995 Fleetwood Bounder 36JD gone
Executive45
Unplug it. Mine runs off the inverter and who knows what the shop technicians will be turning on. They usually need the fridge to keep their beer cold...:)..Oh! and be sure to leave some fresh water in the tank for the toilet flush.....Dennis
accsys
ford truck guy wrote:
I unplug mine...
+1
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
DownTheAvenue
I would look at the refrigerator's owner's manual.
wa8yxm
2chiefsRus wrote:
I would shut off the breaker to the fridge.
Second that suggestion
I unplug mine...
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
rk911
filrupmark wrote:
What about the temp control switch inside the refrigerator .
yup. just keep increasing the temp setting and the fridge/freezer will power off. at least our whirlpool does.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
filrupmark
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
2chiefsRus
STBRetired wrote:
Turn off the inverter.
that too
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
STBRetired
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
2chiefsRus
Dave & Kathy
Our Blog
