Sloppy steering
rsn48
Purchased a 1994 Winnebago Adventurer 32 feet, Chevy engine and overall I am thrilled with the unit, well maintained and very clean with only 61,000 miles on it.
But.......... the unit has very sloppy steering at faster speeds like 60 MPH plus, even in a straight line. My understanding is there are things you can do to address this issue, would love help and suggestions on this.
19 REPLIES 19
SoCalDesertRid1
The screw on the steering box adjusts the gear lash. The gear lash is set when the gears are new. If the lash is now loose, it's because the gears have worn out. Screwing it in tighter will only finish wearing out the gears faster. If the gear lash is loose, replace the box with a rebuilt one.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
Naio
Sometimes there is an adjustment screw on the steering box. My understanding is that you do this LAST, after making sure alignment and suspension are good, so you don't cover up a dangerous problem. Worked for me, after several tries (too tight, too loose, just right). Before you get an actual new steering box.
If you are not doing the work yourself, you need a mechanic who is willing to adjust it several times to get it good.
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
Harvard
Too little front end caster can manifest itself as "loose steering" (and wandering) at highway speeds.
Artum_Snowbird
If you have a steering stabilizer shock absorber, replace it. It made a huge difference to a wandering steering wheel for me.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
MountainAir05
Bell crank or idle arms.
