Solar Panels
Fer2005
I'm thinking of putting a bigger solar panel on my rig, 09 Winnebago Journey. I've looked but haven't found the answer to my question. It could be out there but I've missed it.
My question is, can I take a bigger wattage solar panel and bolt it to rig using the existing factory wiring or do I need to add newer electronics?
Thanks in advance!
2009 Winnebago Journey 39Z
2012 Ford Taurus Toad
3 REPLIES 3
hmknightnc
Need a little more information in order to help you out as answers highly depends on what you have now and what you are trying to do.
What size panel do have now?
What type controller are you using, PWM or MPPT?
What size (amps) controller do you have?
What size panel are you planning to get?
What size wire is your factory wiring?
How much battery capacity to you have?
What are you trying to do with putting a bigger panel on?
WyoTraveler
Depends on size of your controller, amps Vs wire size. If you have a PWM controller you may be able to switch it out for a more efficient MPPT controller. They claim 30% more efficiency in use of same solar panel.
diveman52
Yes and No
How about a lot more information
What gauge is the wiring to your existing panel?
How long is the run to your charge controller?
What type, model number, amp rating of your charge controller?
What size wiring from charge controller to battery bank?
What size panel do you want to upgrade to?
What is your battery capacity?
40+ Years in Electrical construction.
Retired IBEW Local 595
Every Days Saturday
2008 Newmar Dutch Star 4035
