something wrong
dcbrewer
Well took the chassis battery cable off to hook up the battery tinder, the steps still worked, than I tried the ignition and the engine started with the chassis battery cable off. Could the emergency switch be stuck. I know my chassis and house disconnects both quit working the last time we used it, haven't had time to check it out yet. guess I have plenty of work to do this weekend. Were to look. 06 Pace Arrow, 36D, Workhorse chassis. Thanks for any help!!!
2 REPLIES 2
dcbrewer
Mines not wired wrong, because have had to use it a few times, when the chassis battery was low. Always had to push both switches in to work. Thinking must have a solenoid stuck, if I can find it.
Mandalay_Parr
Found out my boost switch was wired wrong and the solenoid was ON all the time.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
