Source for EZ Ramp Levelers
Bordercollie
Need a few more of the yellow plastic EZ Ramp RV levelers that were common ten years ago. They were made by RKRP, Inc, Brownsville Texas.
Alternately, would like to buy some levelers that are the same configuration and would work with the EZ levelers. The current Valtera levelers look like they might fit together with the EZ's.
brown
6 REPLIES 6
IAMICHABOD
Bordercollie wrote:
I never had the EZ leveler blocks break but didn't use them a lot. May go with the Tri-Leveler type.
They will fit nicely in your under floor storage at the rear drivers side compartment.
4 will fit easily.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Dusty_R
I use 1x6, 2x6, & 4x6 boards. The 4x6's I cut about a 30* angle/ramp on one end.
Cobra21
I bought a set from Amazon a couple years ago for my son. I have used these lego blocks over 10 years and haven't ever broke one.
Brian
Bordercollie
I never had the EZ leveler blocks break but didn't use them a lot. May go with the Tri-Leveler type. I did see a set of used EZ's on Ebay but don't buy from Ebay.
IAMICHABOD
With my previous RV,a Class A, I made wood ramps like these
I found that they were heavy and very hard to store.
With I bought my Class C I tried the Lego type blocks but found that they broke to easy and were a pain to setup when you don't get it right the first time and had to drive off,re-stack, and make them higher,to labor intensive.
When I bought my RV,a Former Rental, it came with Tri Level Ramps They don't break and if they are good enough to withstand the use in that market they must be good,they still put them in their rentals
I have used them a lot in the last 10 years and have had no problems and they are easy to use and store. I have 6 just in case but never have used them all,4 is the most I have ever needed,most times just 2 if at all,they were for the rear duallys.
I found that The Tri leveler work very well.
pushtoy_2
i had yellow levaler ramps from cw they were junk broke the first use ..i have the square blocks that you stack. i use car floor mats under them on gravel work great
DREAMER FMCA200924
GS Life member
