โApr-16-2022 04:44 PM
โApr-21-2022 03:38 PM
โApr-21-2022 02:25 PM
โApr-21-2022 01:16 PM
sssooo wrote:
:SIf this works how do I get the steps back in?
โApr-21-2022 01:12 PM
โApr-20-2022 06:51 PM
Bud
USAF Retired
Pace Arrow
โApr-20-2022 06:46 PM
โApr-20-2022 03:41 PM
sssooo wrote:
My mistake I do have power to the red and white wire I put a new clip on my test lite works better
Now my back hurts!
โApr-20-2022 10:24 AM
โApr-20-2022 06:14 AM
enblethen wrote:
Here is a diagram for most Kwikee steps. They have over the years switched the magnetic switch from normally open to normally closed, wait was it normally closed to normally open.
Kwikee step diagram
Yes the switch does provide a ground to the controller but it is not a good ground for testing. If you had a multimeter it would be used to verify switch operation. If your test light has a continuity operation, it could be used for checking switch.
Best ground for testing would be one to frame. You could take the motor ground, large green wire, loose from the frame, clean the frame good, reattach and use it for testing and ground for motor.
โApr-20-2022 05:57 AM
Bud
USAF Retired
Pace Arrow
โApr-19-2022 09:47 PM
โApr-19-2022 07:06 PM
Bud
USAF Retired
Pace Arrow
โApr-19-2022 06:56 PM
sssooo wrote:
Would that be f22 or f 13?
โApr-19-2022 05:29 PM
