Strange Window Leak.
Menander
Have a 32' Fleetwood 2001 Bounder. Some of the sliding windows developed a leak when it rains. The water seeps out from behind the screw heads on the interior bottom edge of the window. Any clues? Doesn't seem to be a caulking issue.
Thanks!
7 REPLIES 7
Menander
Thanks for the tips!
ScottG
My buddy and I searched his new Arctic Foxx TT many times trying to figuring out why a window always had a wet spot under it. The window had a crack in the glass (not related to leak) so he bought a whole new assembly. ($60)
When we removed the window and inspected it, we found a tiny void in sealant that was used where the extrusions of the window came together.
path1
Pull couple screws at each corner at top of window. If one side is lots more rusty than other side you could have a leak coming in from above. The water you see is flowing down to the weep hole drains from above. Easy to check out.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
MountainAir05
Clean and reseal the caulking , if not bad check the roof line.
Menander
They seem to be clear...no debris
darsben1
window drain plugged.
Traveling with my best friend, my wife in a 1990 Southwind
DrewE
Are the weep holes (on the outside, in the bottom frame part) clean of debris? That's one usual root cause of this sort of problem.
