Sub floor
SteveSr
Having carpet replaced and have a soft spot in shower area. the installers are concerned about sub floor. Is it simply plywood? It is a National Tradewinds. Suggestions appreciated, thanks.
6 REPLIES 6
jspringator
If you can get it dry and have access from above, You could use several treatments of Rot Dr.s CPES. It is very thin and penetrates very well.
http://www.rotdoctor.com/
Jim & Sherri
02 Winnebago Sightseer 27c Class A;
"Scout" Springer Spaniel, gone but not forgotten;
"Boo" Chocolate Labradoodle.
rgatijnet1
prior to replacing the carpet, and after the damaged sub floor is replaced, I would coat the entire sub floor with at least two coats of polyurethane. This will not only help protect your floor from water damage but will also help eliminate any odors from the existing carpet.
On some coaches, like mine, the sub floor is laminated to foam to provide a thick sandwich type of floor that is well insulated.
AikenRacer
Just a suggestion...I recently replaced a totally rotten floor in the basement compartment where all the plumbing is located. I used a sheet of HDPE which is hard plastic sheet. It was easy to cut and work with. Sort of expensive but you'll never have to worry about rot, soft spots, etc.
2012 Tuscany 42RQ tag
2005 Silverado 2500 w/ piggy back golf cart
wolfe10
Pulling back the carpet will give you the FACTS very quickly. Many are OSB.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
1492
Moderator
Moderator
Moved from Forum Technical Support
You_can_t_take_
It's probably just regular plywood. If you're concerned about it happening again replace it with pressure treated plywood.
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: 2002 Cougar 276EFS; 2005 Laredo 29GS; 2002 GMC 2500HD Ext Cab 4x4; 2015: 2006 Class 'B' Chateau Citation; "(Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
