Sunseeker 3170DS manual slide extension?
cardtarget
I need to replace the rear motor of my giant slideout which is currently retracted. I took apart the inside of the unit to access the motor, which I found, but it appears that it must be released and replaced from the outside.
But I can't extend the slideout... and can't figure out how to do it manually. I've tried removing power and control wires from both motors. I don't appear to have any type of 5/8 inch manual system...
Any thoughts?
3 REPLIES 3
cardtarget
Anyone every tried to jack it out? Or done it? I don't have access to a bunch of people.
If one side motor is working, can I disconnect the other side and push just on that side?
klutchdust
A quick look around the internet says to push it out manually. Recruit the local high school football varsity line .
bobndot
Im of limited help because my Sunseeker is a non slide unit.
Were you able to get info on the FR forum ? I just ran across this regarding slides.
http://www.forestriverforums.com/forums/f18/2014-sunseeker-3170ds-bedroom-slide-inop-156429.html
