surge protector????
the_silverback
I was checking the camping world website for surge protectors. When I checked the reviews I saw a lot of them did not protect. A couple of reviews said they actually damaged equipment in the RV. What is your experience????
the silverback
2015 crossroads Rushmore 5th wheel
22 REPLIES 22
hanko
4aSong wrote:
2chiefsRus wrote:
Progressive Industries is the way to go.
X2 And it comes with a lifetime replacent guarantee
Plus its hard wired and permanently mounted out of the weather and thieves
2014 Tiffin Open Road 36LA,Banks Power pack,sumo springs, 5 star tune, magnum invertor
2013 Ford Focus Toad
Haigh Superstar
4aSong
M & N
Tundra TRD V8 4x4 w/Leer Shell
EU2000i * Prodigy * McKesh * Trek * Renogy * ENU
DrewE
There are two broad types of devices that are generally sold as RV surge protectors, and they have wildly different capabilities.
One class is just basically a larger version of a surge suppressor power strip such as might be used for home computers. These provide rather limited protection against transient voltage spikes, and nothing more. (Some do also have little test lights to indicate miswired outlets, identical to those in the three light outlet testers you can get.)
The other class is perhaps more properly described as a simple EMS (Electrical management system) and has a contactor controlled by a little computer that monitors the power line and cuts power off if various anomalies are observed, such as low or high line voltage, reversed outlet polarity, disconnected or unbonded ground connections, etc. These generally also have MOVs to protect against voltage spikes.
The latter kind is considerably more expensive but IMHO well worth the extra cost. Protection from low line voltage, in particular, is useful and important for the longevity the air conditioner and some other appliances. Low voltage is not uncommon in campgrounds.
sailor_lou
Which ones are you considering? Some only provide surge protection and the better one also provide high/low voltage and frequency protection along with a myriad of wiring faults (open neutral/open ground/polarity issues). Whether or not they will protect from all surges is doubtful (in my mind), but a campground wiring problem (esp. low voltages) is a real threat making the device worth every penny. Also, I see no way any surge protector will actually cause damage and I worked as a power plant engineer for 30+ years.
FWIW, I have the Progressive Industries EMS-HW50C (see below) and it has protected my A/C units many times on low voltage at some of the older campgrounds we have here in the northeast.
EMS-HW50C
Lou
05 Travel Supreme Envoy
2oldman
Surge, Class A, 2011
Surge, 2013
2chiefsRus
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
Doss
looked at the Surge Guard on amazon
I will spend some money but not sure I am down with a $350 surge protector.
They do have the non lcd version for $96
2022 Cruiser RV MPG 3400BH
2022 Chevrolet 2500 HD 4x4
Bob___Ann
We use the Surge Guard 50 AMP portable unit and it works well for us. It has cut the power off several times at different locations due to low voltage. It tripped once for a park that was not wired properly. It also saved us once from a lightning strike. It hit a tree about 50 feet from us. Other units around us had damage while we were saved. As stated, it has served us well.
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17)
Chihuahua - Lola (Rainbow B 12/26/18)
Autumn-Red Poodle
2019 Tiffin 40 IP Bus
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2021 Jeep Unlimited Sahara Toad
Demco Dominator & Airforce One
