Mar-31-2018 04:37 PM
Apr-03-2018 08:25 PM
Apr-03-2018 07:25 PM
S1njin wrote:IAMICHABOD wrote:
Front Sway : If you don't have levelers then upgrade the puny undersized stock Anti Sway Bar with a Hellwig.
What do levelers have to do with upgrading the front sway bar?
Apr-03-2018 02:51 PM
S1njin wrote:
I ordered both front and rear bars from SDTruckspings.com. Apparently Hellwig is a build to order type place so now I wait awhile. Got my alignment scheduled with a truck shop the day after we get back from our shakedown trip.
Apr-03-2018 02:11 PM
Apr-03-2018 11:40 AM
Apr-02-2018 06:18 AM
Apr-02-2018 04:14 AM
kerrlakeRoo wrote:
I've been curious on something like this too. Has anybody tried driving the Jayco Greyhawks with their J-Ride compared to the other units standard configuration. Jay ride plus is on the Greyhawk line.
J-Ride plus adds
Bilstein shocks,
Helwig helper springs
Front and rear stabilizer bars
rubber isolation mounts
It would be nice to be able to talk to a delivery driver with time in several brands to get a comparative view.
Apr-01-2018 08:31 PM
Apr-01-2018 08:00 PM
Apr-01-2018 05:05 PM
Apr-01-2018 03:10 PM
OFDPOS wrote:
Contrary to what others post about NOT getting pushed by a semi PASSING them once they did an alignment or even all the above is lying to you...
It may help some to a lot , but you are still going to get pushed by a large SUV on up to a semi passing you.
Have read where people say they don't get pushed by a semi only to say they don't get pushed by a semi while PASSING THEM , big difference in passing and being passed... You still are going to get pushed ...
Sorry don't know how to do the click here link, but this little video shows the effect of what happens when passed by a semi in layman's terms...
http://blogs.discovermagazine.com/d-brief/2017/08/28/vaping-next-to-truck/#.WsFU8YjwaUk
Apr-01-2018 02:56 PM
S1njin wrote:
So what is the consensus best order of suspension improvements on a E450 motorhome?
My guess:
Proper Tire Pressure : Load it up like your leaving to go on trip then weigh it , set tire pressures according to weight.
Front end alignment : While still loaded for trip go get an alignment done.
Rear Sway : If it doesn't have a rear Anti Sway Bar or does have the puny undersized ford one ? Put a Hellwig on.
Shocks : For now leave the fronts alone, and if you slam going over bridge joints or even driving over cracks in the road (since Koni's are suppose to work on the rebound I'll give them on that)
Replace the rear shocks with the Koni's FSD , myself I'd replace the rear with Bilstein's.
Steering Stabilizer : More for a blow out , but does help very very little on side-wind or very very little pushed from semi's passing you. So it would be Saf-T-Plus if you want to replace Fords joke of a steering damper .
Rear Track Bar : You are boarder line length wise for a Trac Bar.
But if you are going to tow then yes a rear Trac Bar will help.
Am i close?
Apr-01-2018 10:55 AM
Mar-31-2018 08:29 PM
Mar-31-2018 07:59 PM
