- crassterExplorer III'd use wood filler or auto body repair to fill them.
- BumpyroadExplorer
TucsonJim wrote:
I just got off the phone with my brother who is a contractor that does a ton of remodeling. When he encounters a hole in a hardwood floor, he fixes it with a hole plug and then matches the stain so the repair is almost invisible. Check this YouTube video that shows the process:
Repairing holes in hardwood floors.
Jim
yep, get a piece of matching/similar hardwood, use a forstner (SP?) bit and make a smooth hole in the existing floor, use a plug cutter bit to cut some patches out of the piece of hardwood you bought.
bumpy - TucsonJimExplorer III just got off the phone with my brother who is a contractor that does a ton of remodeling. When he encounters a hole in a hardwood floor, he fixes it with a hole plug and then matches the stain so the repair is almost invisible. Check this YouTube video that shows the process:
Jim - DSDP_DonExplorerSince it's would, I think "johnsonbert" suggested the best idea.
On the carpet, find a piece that's a little oversized and cut the visible end (slide edge) to size. You should be able to find a local place that can add an edge. Have them bind the one side and you'll be ready to go when the time comes. - MoffittclanExplorerI thought about the rug idea but opposite of that is the slide with the couch and it has carpet (carpet that needs replaced but I don't know how to get a piece with bound edges that is custom to that slide...another post later). I was worked that putting a rug there might look kind of hodge-podge (sp?). I do like the idea of making plugs...guess I'll see what I have after I remove the loveseat...
- johnsonbertExplorerDepending on the size of the holes, you may be able to fill them with an epoxy and then find a piece of flooring that nearly matches your flooring and make plugs to fill the holes, as they would in furniture making. Just a thought. If done with care, the grain could align and be nearly perfect without sanding or finishing of any kind. Hope this may help, Happy Trails Bert
- KRummExplorerhttp://www.amazon.com/Safavieh-Mahal-Collection-MAH625B-Natural/dp/B017NMBKKQ/ref=sr_1_29?s=furniture&ie=UTF8&qid=1459861073&sr=1-29&keywords=Persian+rug&refinements=p_n_size_browse-bin%3A369535011
About Motorhome Group
38,707 PostsLatest Activity: Jan 05, 2014
