Sway bars, steering shock
BeaverCamper
We just sold our Class C and are purchasing a Class A (Thor ACE 27.2).
Our Class C we needed heavy duty sway bars and steering shock to make it handle reasonable well.
Will that be required on the Class A?
Thanks!
Beavercamper
BeaverCamper (2019 Coachmen Leprechaun 260 DS)
2 REPLIES 2
wa8yxm
I recommend a good steering stablizer like a Blue Ox Tru-Center (what I have) or a Safe-T-Steer with optional remote re-center (not offered when I had mine installed)
Also at least one track bar if not two (Rear and front in that order ( I Have a front one plan on the rear... Some day)
Sway bar may or may not be needed depending on the one that is already there.
Mine did not need it .
craig7h
Nomad II
Nomad II
There is alot of talk about this on the Thor Forums www.thorforums.com/
Myself on my 29.3 ACE have found no need to adjust the sway bars or add the safe steer type of system. It takes alittle getting used to, and yes driving with a strong cross wind is not fun. Remember this is a big box going down the road.
Itasca Meridian SE 36g
Road Master Tow Dolly
