Switches in bathroom and fridge not working
Dld123
Wondering what the 2 switches on the wall by sink in my 1993 passport/ cobra are for? Rvs plugged into shore but cant get refridgerator to switch to elec.
Deb
8 REPLIES 8
Bordercollie
One of the 110volt AC outlets may have a GFI reset button that needs to be pressed, hear it click.
Dld123
Thank you so much. Im checking all that now. Im surprised at how much maintenance and knowledge is needed to live in an RV! I appreciate this forum.
bobndot
Open the outside panel that allows you to view the rear of the fridge. Make sure its plugged in. There should be an outlet dedicated to the fridge.
Some people unplug them because some older and state park campgrounds that insist on using GFI outlets for 20 amp service will constantly trip when some rv's plug into them. Those people will unplug the fridge and run it on gas 24/7.
Do you have a bathroom fan in the roof vent ?
how do you turn it on/off ? There is a small switch on the fan itself but some rv's also use a wall switch. Same goes for the bathroom light, some have two switches.
It could also be a dump valve light switch if you have an outside light near the dump valve.
corvettekent
The fridge power switch should be on the fridge door.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Dld123
T.y. all..the fridge is original norcold that came with rv...well I do know where the water heater and pump and every other switch is.
I looked everything over and there's also 2 switches as you walk in the front door.Just like the 2 n bathroom. Im wondering if any of these could control my fridge.
I bought the rv for temp home..I know nothing about rvs...
Sjm9911
Make /model/ type of fridge would help a bit. Is it original to the camper?
2012 kz spree 220 ks
2020 Silverado 2500
Equalizer ( because i have it)
Formerly a pup owner.
stickdog
One could be for water pump.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
midnightsadie
one could be hot water heater/DO NOT flip switch intill hot water tank is full. other switch?
