TPMS Settings
kmeyer319
Hello! I have Goodyear G670 RV tires on my Class A motorhome. I am setting up my TST TPMS, but unclear what I should set the Hi/Lo temperature and pressure alarm settings. Can anyone lend some advice?
Ken
11 REPLIES 11
dodge_guy
TST gives you their settings and tells you to leave it there. that`s where I leave mine at.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
bob213
I believe TST manual says default temp should be fine and pressure should be 10% below and 20% above your cold tire pressure.
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
Executive45
Leave the temperature at factory settings. They don't recommend you change those. As for the pressure settings, weigh your coach. WEIGH YOUR COACH. Did I remember to say, weigh your coach.? Yes, I did. That's the only way you know what your tire pressure should be. Once weighed, go to Goodyear's site and air up accordingly. I set my tire pressure about 15 psi above and about 10 psi below what I have them aired up to. Hope this helps...oh! and weigh your coach. ๐Ÿ™‚ ....Dennis
cummins2014
rgatijnet1 wrote:
Upper temps will vary greatly with the season and the location. I found that the upper temp limit is really not too critical as long as all of your tires are running in the same approximate pressure range.
Set your TPMS for about 20 psi over what you feel is the correct psi based on your coach weight. Set the low for about 10 psi lower than your optimal pressure and just see how things go.
What you are looking for is one tire to do something strange like running way too hot or the pressure going way too low.
Do not do what some people do during the Winter low temperatures and ignore the low pressure warning in the morning and just drive until the tire heats up and the alarm goes off. Adjust your tire psi as outside temperatures dictate.
I started out in cold temperature, and set my tire pressures accordingly, and drove into a much warmer temperatures within hours , and I got some crazy high pressures plus the warning . I now know that I can set my tires at a little below what I like, not a lot . My tires I set for 100 psi normally , if real cold Iโ€™ll set them for 95 , most of the time getting in the warmer climate they will be at a 100, sometimes more so I will let a little out .
CA_Traveler
The cold inflation should be set per the load inflation table. I've seen 140F+ on my tires.
I've replaced 2 sets of G670 tires with river edge wear.
2014 Grand Cherokee Overland
Bob
cummins2014
kmeyer319 wrote:
RV tag says 95 cold and side wall says max load pressure 110. Goodyear website not much help.
Are you asking about your tires or your TPMS , I thought you were asking about the TST , the book tells you what you need to know :h
cummins2014
Ken
Follow the guidelines in the book , it calls for 20-25 % on high pressure , I went 25, mine creeped just over the 20 %. So I reset at 25 . I left the temperature at the default at 158. And 10% on low pressure.
rgatijnet1
kmeyer319
dedmiston
Moderator
Moderator
Moved from General RVing.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โ€ข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โ€ข <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Lwiddis
What is the Goodyear and MH manufacturerโ€™s recommendations for tire pressure?
