โMar-15-2020 05:03 AM
โFeb-15-2021 01:10 AM
โFeb-12-2021 01:29 AM
โFeb-09-2021 09:49 PM
โFeb-07-2021 11:34 PM
โJan-25-2021 11:21 AM
โJan-18-2021 05:09 PM
Stim wrote:
I have drilled a few hundred holes in semi frames mounting axles/equipment and I can't imagine using battery tools!
We used a 1/2" drill with a "D" handle AND put a chain around the frame through the "D" in a loupe. With chain tight you rotate the drill which forces the drill into the hole.
In your case you might try a rope around the frame and drill to get more force.
You also must use slow speed with lub.
โJan-18-2021 04:25 PM
โJan-17-2021 06:55 PM
โJan-17-2021 03:53 PM
โJan-17-2021 03:50 PM
โJan-17-2021 03:37 PM
โJan-17-2021 03:21 PM
โJan-17-2021 03:11 PM
MrWizard wrote:
Bits are from new set, titanium coated,
Richard you were under the rv ?
Pushing up ? Solid ground under you
Correct ,?
You do realize there is a huge difference in the amount of applied force that can be maintained,
Given that you were an immovable object which could not be moved,
And my applied force was also pushing me away from the rv, remember physics, equal opposite reactions, you could not be moved the drill had to go forward into the steel, in my case the cutting force was actually 1/2 of the energy I was putting into it, nothing behind me keeping me immovable so all force is on the drill bit
Yes I want to get harder drills, that stay sharp longer, also going to get some friend, younger and heavier to do the drilling
But Not today, I'm exhausted, maybe later in the week or next weekend
Yesterday was much too tiring
โJan-17-2021 10:34 AM
