I have a 2009 Damon Challenger. Recently I started having a problem with gauges on the main control panel. While the motor is running, the fresh water, black water, gray water, propane and battery status gauges operate as expected. If I shut down the motor, these gauges go dark. Battery status on house and engine batteries is good. Whether operating from house batteries or shore power, no gauge readings. Turning the ignition key to auxiliary position fails to activate gauges. The only time I have functional gauges is with motor running. Anyone have a suggestion as to how I can track this gremlin down?
