Thor Freedom Eilte B/U camera
geojule
Hey all, need some help . I have a 2016 Thor Freedom elite and when hooking up the house batteries recently The positive cable grounded and sparked , blew 2 fuses in panel both 40 amp and the fuse behind the radio in the bedroom . The rear camera doesn't work and I've tried to look for a fuse ...cab , engine compartment , behind the Axxera audio / video in the dash and also pushed the reset on it. I tried to pull out the camera and couldn't get the cable out of the hole ( not much wire ).
Searched and checked all fuses that I could find...
Thanks in advance
Geojule....
4 REPLIES 4
geojule
bobndot , I think i figured it out , the camera is bad...But thx for information..
bobndot
Don’t know if he still in business or not but there was/is a small rv shop in Gansevoort . 11 Circle Dr.
geojule
bgum , I reset it ....oh well ....
bgum
Right below the on/off knob and right above the aux input is a slot with a hole on its right side. Tiny. Push a tip of a paper clip in the hole that is a reset do that with it off. Then turn the radio on and select rear camera.
If that doesn't work your finished.
