Thor Vegas/Axis engine Batt.removal thru hood.
jolooote
Yes, it can be removed thru the front hood opening if you don't want to 'SAW' thru the inside dash top. The battery height must be less than 7.3/4 inches high. Unplug MoHo from 115 Volt Ac. Put switch in the Storage Mode. Under the step, push the Aux. batt. disconnect button. Open the hood.
1. Remove the 2 large air vent hoses. 2. Remove the 2 screws from the Air Conditioner expansion bottle. Move bottle to the left of the battery and push the 2 hoses behind the batt. 3. Remove the 1 front bolt from the black angle iron support arm and slide the arm to the right as far as it will go. 4. Remove the ground and 12 volt cables from the batt. Also remove the additional 12 volt cable from the positive connector and insolate with lots of rubber tape.(Lay this cable to the left of the Batt. 5. If not already present, slide a strong strap under the batt. and tie tight atop Batt. to provide a lifting strap. 6. Apply electrical tape to the Batt. Post to insolate them just to be on the saft side when lifting the Batt. Lift it up, slide forward and out. :B
Joe & Charlotte
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
2012 Jeep Wrangler 285hp V6 'TOAD'
Gabby & Molly are Dogs
Leroy's a Conure, Loretta's a Squeaker
"Once it starts breakin'...GET RID OF IT!!!"
12 REPLIES 12
4x4van
Thor actually designed, built, and sells an RV that requires that much work to replace a battery? :S
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
krivanj
My service guys, independent shop, did one by cutting a hole in side of Coach and fitting a specially made door into the cutout hole.
They said the door had come with the coach for when it was needed, just not installed.
Fleetwood Revolution LE 38X
2011 Scion TC toad
Dutch_12078
Yep, either way, azrving nailed it... 😉
Dutch
2001 GBM Landau 34' Class A
jolooote
BTW; Even if you 'Choose' to remove it thru the Dash, The same stuff is STILL in the way. You'll still want to remove the 2 big air vent hoses that go across the battery top and the AC canister hoses that also go across it and also the 3rd 12 DC cable that crosses atop the batt. and feeds the Coach battery Paralleling relay. lol
Joe & Charlotte
doughboy
I'd take it to auto zone. they replace them for free
Larry, Lisa, and a dog named "Pepperjack"
2000 Excursion,Toreador red,diesel
2013 cruiser, viewfinder,
Waitin for my ship to come in
jolooote
Just sayin..."It can be done" OR Chop a big HOLE in the dash, not to mention NO ONE says HOW to close that BIG HOLE.
Joe & Charlotte
donkeydew
do it on a you tube so we all can enjoy (not)
1968mooney
Best to get a BOOST then go trade it for a new vehicle. :S
Ozlander
azrving wrote:
Another one where the person designing it has never held a wrench.
And not knowing the battery needs to be replaced at some point in time.
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
Dutch_12078
Yep, compared to the common "Open hood, disconnect cables, loosen/remove hold down, lift out battery" process, it sure does seem more complicated than it should be.
Dutch
jolooote
Joe & Charlotte
azrving
