I took a big chance and had the Auto Skills Shop on the nearby Navy Base:
1. "Flip" two tires on their rims so I could try to equalize some odd wear patterns.
2. Install Metal Valves in Front and Spare Tires
3. Install Borg Dually Valves (one of the "TireMan KnockOffs") on the Rear Wheels
4. Balance all seven tires
I showed them and gave them the instructions to install the Borg Valves and they used the included Loc-Tite. They spin balanced the wheels and used adhesive strips of weight to make the adjustments. Maybe I was just lucky but the job was outstanding. They would NOT do them "on" or "from" the coach. I had put it up on stands and brought all seven mounted tires in aboard our van.
Let me offer this: IF you're satisfied with the balance of your wheels, install them with those heavy custom stems opposite each other. It'd be tempting to put them side-by-side for convenient checking, but my personal belief is that adding pretty much the same weights 180* from each other will not make that much difference in the overall balance of a pair of rear dual wheels as an assembly.
I've heard of installing these valves at home as follows:
Block the Vehicle from Rolling
Remove one Set of Dual Wheels and Place Axle Weight on Jack Stand
Remove Valve Cores
Put One Wheel Under Coach Frame, Valve Side UP, on Side of Coach WITH wheels still installed
"Jack" the Vehicle with Bottle Jack Base on the Tire, right at the Bead, by the Valve Stem and Top of Jack under Vehicle Frame
This should "break" the Tire Bead at the Valve
Install new Valve, Loc-Tite and all
Repeat for Second Tire
Air Up and Install Wheels
Repeat for Opposite Side of Coach
