Tire Question
gb76087
I have Michelin tires installed new in April 2013. Noticed this weekend that the left front tire is starting to show sun/weather cracks. Not sure why, as the MH doesn't sit parked for more than a couple of months at a time(none of this time is summer), and then it is kept in a open covered storage facility. The tire in question is facing east when stored. So, the question is What to Do? Would it make sense to move the tire to an inside position on the rear or should I leave it where it is and begin treating it with UHV protection and become more diligent in keeping it covered?
2007 Fleeteood TERRA LX 34N
F53, 362hp V10
16 REPLIES 16
ArchHoagland
Check with Michelin, there is a good chance they will replace it.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
brirene
Seems that's been a common problem with Michelin in recent years. I would check with the installer or Michelin to see about warranty replacement. No reason your safety should be compromised if it's a defect.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
