โOct-30-2021 03:30 PM
โNov-06-2021 04:24 PM
donkeydew wrote:
sure have the one that sticks out was getting caught on the ice field parkway in blizzard conditions all the way to lake Louise not fun but no problem with the tires they held the road much better than i would have thought they would
โNov-05-2021 06:32 PM
KendallP wrote:donkeydew wrote:
i am on my 3rd set of toyo's.
i have driven the motor home all over the western us and northern canada in all kinds of weather with out a problem.i would save the money on siping them.
Most helpful post yet. Very reassuring.
Thanks!
You say "...in all kinds of weather..." Does that include snowing and sticking? Or just snowing? Have you driven that 40 foot DP on snow-covered roads and on ice with those Toyos?
โNov-03-2021 10:25 AM
โNov-03-2021 10:17 AM
valhalla360 wrote:
So 3 comments and they are horrible tires? That's hardly a decent sampe size.
There is a difference between saying they are "suitable" and saying they are "not recommended"...you are adding something that isn't there.
โNov-03-2021 12:21 AM
KendallP wrote:
Responses in blue below...valhalla360 wrote:
You were the one indicating it was MH owners. Quote: The Toyos are considered to be (by motorhome owners)... one of the best replacements. Yes. And?
Lots of comments are just as likely a result of them being a commonly available model. If 1% of people complain, you will have far more complaints from a tire that sells 100,000/yr vs one that sells 20,000/yr. You yourself, indicated the Michelin was a popular tire for this application. When? They came with the rigs. And I said there were only 3 reviews on Tire Rack... with the first review in 2011... meaning they've likely been for sale on that site for at least 10 years. That doesn't ring as very popular to me.
If Toyo says they are "suitable" as drive tires, they are suitable. "Suitable?" Yes. "Recommended?" No.
If you think you know better than the manufacturer, go for it. As stated many times... I don't. And I'm not planning on siping the tires.
โNov-02-2021 06:29 PM
โNov-02-2021 08:47 AM
โNov-02-2021 01:44 AM
KendallP wrote:
1. I was not talking about design. There a tons of reports, here and other sites, of very early sidewall checking on the Michelins, despite very little UV exposure. I don't know where you got that MH owners are critiquing the design. They're simply reporting what happened to their OEM tires. Perhaps Michelin has solved that problem. If more owners hadn't felt burned by Michelin, I'm sure more of them would have stuck with the OEM tires to find out.
2. The manufacturer designed the Toyos to be best suited as steers. If you go to the webpage for these tires, you will see them "Recommended" as steers and "Suitable" as drives.
And if you click "Drive" tires, "22.5" on the same Toyo website, you will not see the M154 model listed.
The problem is, Toyo doesn't have a drive tire anywhere near the same size as the OEM. Nor does anyone else that I could find.
โNov-01-2021 02:42 PM
rhagfo wrote:
I actually had used tires sipped at LS, they were about 50% tread and had poor wet traction. I had them sipped and far less tire spin on take off.
โNov-01-2021 01:52 PM
toedtoes wrote:
That you have voiced several times a dissatisfaction with the Michelin tires, just makes all this seem silly. Why would you even consider trying to duplicate a tire of which you think so poorly?
โNov-01-2021 01:21 PM
KendallP wrote:
The point here is... they appear to have opted for some kind of siping... that looks a bit like aftermarket siping... for these tires targetting the motorhome market.
The question is, should one consider trying to mimic that with aftermarket siping... if... like many... you are not confident in the OEM Michelins... and you know there are very few options for replacement of this proprietary tire size.
โNov-01-2021 12:24 PM
rgatijnet1 wrote:
Since the siping on the Michelin tire picture is curved/angled in the top picture it certainly looks like it was molded rather than someone taking a heat knife and cutting uniform angle cuts along the edge. Way too labor intensive for production tires.
โNov-01-2021 11:02 AM
Blaster Man wrote:LouLawrence wrote:
No siping. Run the tire the way it was designed.
Agree, not necessary.
โNov-01-2021 11:01 AM
valhalla360 wrote:
Who are these people you keep referring to? The average MH owner has little to no knowledge of tire design...so your assertions regarding quality are suspect to begin with.
I stand by my original statement that if it was needed, the manufacturer would provide it.
