TIRES
devildog1971
My class A has a 22.5 tire all the way around, a friend at a trucking company (he buys loads of tires the same size that is on our motorhome) A Continental is $520 he will mount and balance free, Bridgestone priced at $530 again mount and balance free. He has been trying a new tire on the market called Ironman $250 same deal on mount and balance, He has run the Ironman on his drive axles since they were new, 50000 miles no problems. The Ironman tire is made in China. Please any and all opinions are welcome a big decision, and if the Ironman tire has any problems it is not for me. I forgot to mention the only tire he does not use is Firestone, he told me he had a few problems that he never had again even with the Ironman Chinese tire. Thought I should clarify the rear tires are three years old the left front is 8 years old it was put on by the original owner when he was out and needed it to get home (he had been carrying it in the basement in case of a blowout and road service could not get one soon enough) the right front steer is one year old. I was advised by my friend that he never changed just one steer tire. With that my plan is to buy two of whichever of the above I decide on. and keep the right steer that is a year old as a spare as of now we have enough storage to do that. Also I have only owned the 2002 Monaco Diplomat for a couple weeks . Which ever way you cut it then it would be $500.00 for two tires or $1060.00 for the non Chinese tire. decisions decisions , always seem to have money involved.
2019 Northern Lite 10-2 EXCDSE Dry Bath 2007 G M C dually crew cab and 2018 Harley Davidson Limited Low
24 REPLIES 24
moisheh
Mike: Big thumbs!!
Moisheh
mike_brez
moisheh wrote:
Listening to a trucker's advice is foolish. I drive an a 8 wheeler every summer. Long Haul. Trailers often have cheap Chinese trailers installed. Trailer tires don't last long so they figure why not. But you rarely see them on steers. The smart O/O's will have Michelins or another high line tire on the steers and often on the drives. When a trucker blows a drive or trailer tire usually there is not much damage to the unit. BUT on our MH's not only is there often physical damage to the body, wiring and air lines can be damaged. EXPENSIVE fix. There are many good brands of Asian tires. They do not sell for $200!! Hankook are excellent and OEM on Navistar and others. Tires is not an item where you want to buy the cheapest available. Nor would you want to listen to the constant hum from cheap tires.
Moisheh
Wow a 8 wheeler. Lol
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
Schanker72
If i could give an opinion, whats the complete size, I took the factory goodyears off after i had two different blowouts within two months and only 19,000 miles on it. I have managed a les schwab here in wa, state. Age is a factor and quality of the tire. Spend a bit of money, get a good brand, do all the same, not two different in front from rear. Contrary to popular belief, you can rotate modern tires and change direction with no problems, for example, the two fronts to the right rear, then the fronts again to the left rear, straight back and to the front, which helps equal wear and longevity. Buy the highest load rating available in your size and if itโ€™s more than the factory load rating, you may adjust air psi, usually a bit higher depending on tread, the higher load rating helps the tire USUALLY not flex as much and helps keep it in a sense cooler, not working or flexing as hard. The more the tire flexes or works, the warmer it gets and can affect life. And remember to ask the place you buy them, especially if its a size they dont go through a lot of, to look at the D.O.T. Number on the side. They might of been sitting around for a few years or more, check when they are off the production line and get fresh ones. I put toyos on my coach, they ride nice and are a good top of the line product in my opinion.
moisheh
Listening to a trucker's advice is foolish. I drive an a 18 wheeler every summer. Long Haul. Trailers often have cheap Chinese trailers installed. Trailer tires don't last long so they figure why not. But you rarely see them on steers. The smart O/O's will have Michelins or another high line tire on the steers and often on the drives. When a trucker blows a drive or trailer tire usually there is not much damage to the unit. BUT on our MH's not only is there often physical damage to the body, wiring and air lines can be damaged. EXPENSIVE fix. There are many good brands of Asian tires. They do not sell for $200!! Hankook are excellent and OEM on Navistar and others. Tires is not an item where you want to buy the cheapest available. Nor would you want to listen to the constant hum from cheap tires.
Moisheh
Tom_Barb
J-Rooster wrote:
I paid around $2,800.00 for my Michelin XRVโ€™s about 3 years ago on the Michelin Advantage program. What I suggest is keep doing your research and purchase the best tire that you can afford. When it comes to tires, brakes or steering I would be very careful in my selection to have faithful equipment! Good Luck, with whatever you choose! Rooster
Like you, I simply won't cheap things out that could kill me.
mike_brez
Just trying to figure this all out. What would be the best tire if you can afford any tire out there
2015 Wrangler JKU
J-Rooster
Bruce_Brown
Moderator
Moderator
Tom/Barb wrote:
subtroll wrote:
If you are an FMCA member look into the Michelin Advantage program which offers a significant savings on Michelin Tires.
https://www.fmca.com/benefits/michelin-advantage.html 888-532-6435
I'm in the process of buying 6 new 255/80 R22.5 for $3714 installed (FET included.)
That's about what we paid, at our local tire dealer. for XA3s
And a LOT more than we paid for our 11R22.5 Bridgestones. :W
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
Tom_Barb
subtroll
2004 National Tropi-cal Sterling 396
2003 Jeep Liberty
Tom_Barb
devildog1971 wrote:
I have the weekend to still think it over. My Friend called me and said his tractors with the ironman now exceeded 60000 miles no problem and semi tractor trailers sometime gross 80,000 pounds if they are holding upper him and I only pay $500.00 for two tires out the door I am trying to say why not and I could mount them on the outside rear. but I did notice the two that are coming off are H rated and the Ironman are J rated and if they are in fact a subsidiary of cooper I will let you know what happens next week
Truck tires are known for their ride.
your whole coach feels the ride.
devildog1971
mike_brez
And just because you get the most expensive tire doesn't mean it's the best.
Another Michelin tire blowout
2015 Wrangler JKU
wa8yxm
Michelin set me bak 450 mounted on site.
