Aug-27-2020 04:26 PM
Oct-07-2020 12:37 PM
Oct-07-2020 09:54 AM
RLS7201 wrote:
If your 35(?) looks like this, you have a 35U
Richard
Oct-07-2020 09:34 AM
jeromep wrote:
Wow, how did I miss your reply till now!
So, I should find a way to attach a photo, but mine is a 35, something or other. I don’t know the initial, not sure where to find it. But I have a walk through bathroom, swing door to the kitchen and a pocket door to the back bedroom. With the two closed the bathroom is the full width of the coach with closet space on the right side and bathroom on the left. If anyone knows what letter, that is, I’d love to know because I can’t find it on any of the documentation that came with the rig.
Anyway, I flashed a light down the open drain on the toilet and it seems like the drain doglegs to the right, and then I presume down. So, the hole to the black tank isn’t straight underneath the commode. I could be very wrong. Maybe I didn’t see it right when I had the drain open and was flashing my light down there.
I appreciate your great description. I’ll keep this in mind if the toilet really does biff it. So far, some elbow grease and some bleach water and the previous owner’s detritus is now gone. We’ve used the toilet many times now and it seems solid, even if it is aged.
Oct-06-2020 08:20 PM
RLS7201 wrote:
I had the exact same issue with my 95 32H Bounder. The riser serves no other purpose other than to elevate the commode. The riser is OEM. All of the black tank is under the floor.
I removed the commode, removed the nasty carpeting on the riser, removed the flange, took off the wood cover and shortened the supports. The 3" ABS plumbing will slide out of the rubber bushing in the black tank. Shorten or replace the ABS as necessary. Adjust length of the freshwater supply. Reassemble and replace the old carpet with vinyl. Add trim as necessary.
I suggest you adjust the new commode height just high enough to allow your feet to be flat on the floor or measure the commode in your sticks and bricks.
I would be glad to talk your through the process, if you like.
Richard
Aug-27-2020 06:30 PM
Aug-27-2020 05:20 PM
Matt_Colie wrote:
Jeromep,
If it just looks old, well, it is old. So is the rest of the RV. If you want it to look new, get so plastic cleaner and go at it. If you want it to look newer, wax it.
The box under the pot is usually because they had to make more room for the black tank, so there is not much you can do about that.
Matt
Aug-27-2020 05:12 PM
Aug-27-2020 04:53 PM
dougrainer wrote:
This is as close as you can get, you select the 14 inch. remember, the 14 inch is to top of lid. Back when your RV was made, it was not uncommon to remove the existing toilet and install that wood riser because the original toilet was to LOW. So, it is possible to remove the toilet and if there is nothing under the existing wood base but the down pipe, you can install a shorten 3 inch down pipe and mount a toilet to the main floor. Doug
***Link Removed***
Aug-27-2020 04:38 PM
dougrainer wrote:
***Link Removed***
Aug-27-2020 04:34 PM
