towing a car
funbiz4all
What kind of a setup do I need to tow a front wheel drive honda accord behind a class a gas winnebago 34ft?
16 REPLIES 16
wa8yxm
I am not a fan of Brake Buddy..
IF Remco Towing says you can tow it, with our without modification, then follow their instructions.
For the tow bar,, Ready Brute with Ready brake or Blue-Ox with Auto Stop are my suggestions... Both are good bars and take care of the brakes.
You will also need a tow light system... A diode kit is the most common.. Most Tow Bar places have those. HOWEVER if Remco says you need the LP-1 Lube pump... it is included.
howdy35
Check your owners manual to see if it can be towed 4 down. I believe nothing newer than a 2004 accord can be towed 4 down because of the change of type of transmission in 2005.
Best of luck.
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime
funbiz4all
I'm sorry I was rather vague. My car is a 2007 honda accord 6cyl automatic front wheel drive. We will be going from PA, to CA the summer of 2015. And full timing in CA with a full time job.
RayChez
The problem hauling a car around on a dolly is that some RV parks you are limited in the parking. Some you have to back into the tight spots and no place for the dolly.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
Dale_Traveling
I four down tow a 1998 Accord Coupe. Four cylinder engine with an automatic transmission. Owner's manual has procedures to shift thru the range of gears to ensure it is in a true neutral.
You'll need a base plate, tow bar, and a (highly recommended) brake system. Also rear lights on the Accord for brakes, turn signals and night time running lights. I use a Ready Brute Elite tow bar with a Demco base plate. For lights I used a diode based system that uses the existing tail lights. All up budget around $1800 for planning purposes but add a couple hundred if you cannot install the base plate or lights yourself.
Costs add up quick which can make a used dolly a good bargain but a dolly will require a bit more effort when using.
2006 Hurricane 31D built on a 2006 Ford F53
Jack_Kay
We have towed a 94 Accord with a manual tranny for about 3 years now. Really easy. We just bought a 2014 CR-V and have to get it rigged for towing.
Jack & Kay
2015 Allegro 32CA
2014 Honda CR-V
FMCA #F341229
crasster
Tow Dolly time. They are easy to use. The car should be small enough to tow behind the coach.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
tommy_g
My accord is automatic. Honda would not say that it was towable. I have towed it 50k plus so far without a problem. From 2013 model on you must use a tow dolly.
1998 Bounder 36s F53 460 V8 Banks power & Honda Accord toad
hanko
Empty Nest, Soon wrote:
We have a 2011 Accord. It can only be towed with the front wheels off the ground.
That's why Accords are not listed in the Towing Guides -- they cannot be towed 4-down.
You need a tow dolly to tow an Accord.
Wayne
unless its a manual tranny, then it can
2014 Tiffin Open Road 36LA,Banks Power pack,sumo springs, 5 star tune, magnum invertor
2013 Ford Focus Toad
Haigh Superstar
RayChez
What year is your Honda Accord? I have a 2013 Honda CRV front wheel drive that can be towed four down. And if it is towable, a Blue Ox base plate with the wiring kit will cost you around $400.00. Then they charged me $500.00 to install it and do the wiring so that the toad will have tail, stop lights that work at the same time as the coach. Now if you need the Blue Ox tow bar then that is another seven hundred dollars or you can probably get one for half that price at Ebay.
I believe I paid something like $1200.00 total when I first started RVing in 2003.
OH! I almost forgot. You got to have some kind of brake system and there are many types out there on the market. Some will cost as little as $500.00 to a high of $1200.00
2017 Buick Envision
sailor_lou
First off, what year Accord and does it have an auto or manual tranny? As identified above, some older Hondas can be towed four down. I've been doing it for about 10 years now with two different model years, all with manual transmissions.
Lou
05 Travel Supreme Envoy
Effy
A dolly and enough tow capacity.
2013 ACE 29.2
jorbill2or
Go to the Remco site as was already mentioned they will have the information you need . older Honda accords are towable 4 down! my automatic 2006 was. there is a "shifting regimen" that must be followed first. If it is towable you will need a towbar , baseplate , lighting harness and brake system .. And about 2- 3 grand
Bill
Empty_Nest__Soo
Wayne
Wayne & Michelle
1997 Safari Sahara 3540
