TPMS gauge which ones are good
midnightsadie
going to buy a tpms system for my 16inch tires ,is there couple brands better than others ,
20 REPLIES 20
wolfe10
Yup, I have had Pressure Pro on the last three motorhomes and have had no problems.
So Pressure Pro and TST would be the two I would look at.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
lanerd
Another popular brand is Pressure Pro.
This is almost a daily subject. I highly recommend that you do a simple search on TPMS and you'll find enough to keep you busy for the rest of the day.
Good luck
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
Explorer1016
TST Customer service is excellent. I have had a few issues with sensors and they took care of my problems immediately, no questions asked and the issues were self inflicted, not even the fault of the product.
You can even talk directly to Dan Covington, President,
as I have several times. 5 Star+ rating from me.
2008 Host 300 Super 'C'
2008 Ford F-550 Chassis
Diesel
4x4
Lariat crew cab
20' enclosed car hauler/garage
'87 Jeep rock crawler
Turbo'd
aubreym
+1 on the TST 507 standard sensors and system. Easy to install and use.
- Aubrey W7OLY
BB_TX
The are 3-4 brands that get pretty good reviews, TST 507 being the most popular it seems. That is what I have and very happy with it.
The TST 507 has user replaceable batterys. And you can get either standard sensors, or flow thru sensors that allow you to add/remove air without removing the sensors. But some have said that adding air thru the flow thru sensor is so slow it is easier to take them off if you need more than a few pounds of air. I have the standard sensors, and since I only need to add 2-3 lbs air in the spring and am good for the season, the standard ones work fine for me. The flow thru sensors are also larger and heavier.
TucsonJim
I use TST which is a major player in commercial and RV TPMS systems. I've used mine for the last 15 months, and 11,000 miles with no issues what-so-ever. Here's a link to the system I use:
TST 507 Flow Through
It has saved me at least one damaged tire due to catching a leaking valve stem.
Jim
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
