Sep-28-2014 10:39 AM
Sep-29-2014 09:43 AM
Calisdad wrote:
Thanks path1. I didn't think about the cooler being plugged. I do have a laser thermometer (heat gun) I'll carry it in the RV so I have some sort of reference until I can get a gauge installed.
I had thought about changing the thermostat but when I looked at where it is all I could ask was 'Man, do you really want to do this?'. I might do it after all. I've never heard of a 'high volume' water pump. Where might I find one for a '94 460?
Sep-29-2014 08:01 AM
Sep-28-2014 07:46 PM
Calisdad wrote:
OK- maybe I'm kicking the can down the wrong road here.
A little history: Ford 460- common problem are the head bolts, particularly rear bolts passenger side. Several years ago I had one break and I managed to drill it out in place and re-tap it. Only I didn't get as many threads as I would have liked to. That resulted in a minor exhaust leak then finally a drip of coolant. A 2-part sealer actually stopped the leak- maybe at the cost of some cooling capacity.
So- It stays within range on grades but I don't want to fry the transmission. Of course if I had the money to put in a 20 year old RV I'd have the heads shaved, deal with the head bolts and put on headers or a Banks system.
What I'm thinking is a cooler and a triple gauge cluster so I can monitor what's going on. Waste of money?
Sep-28-2014 06:12 PM
Sep-28-2014 03:28 PM
Sep-28-2014 02:50 PM
Sep-28-2014 02:48 PM
Sep-28-2014 01:37 PM
Sep-28-2014 11:00 AM
